Hellllllllllllllllllllllllllp!
17 Mar 2004
Think ive been a right plonker!!
I thought I had ordered this:
Gigabyte GA-MA78GM-S2H AMD 780G
But have infact ordered this.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2800
Coupled with a AMD Athlon 64 X2 4850e 2.5GHz Socket AM2.
Will the later still be able to play 1080p using the onboard gfx card comfortable or have I made a big mistake.?
Bloody similar part numbers, was in a rush at work when I clicked buy!
Both motherboards are the same. The only difference is the one you bought is ATX instead of micro-ATX and it has more pci-e slots.
If you have a HTPC case, check that ATX boards fit inside.
This is my case, black thing top right shelf
The case is ATX so it will fit fine. :)
cheers chap, seriously out of touch with PC tech these days. Originally built my setup 6 years ago as a gaming machine in it's hayday, then got fed up with lag etc and converted it into a HTPC case running MCE2005, that is now outdated too. So had my use at least :)
