Hello! CSS HTML help pls.
Permabanned
22 Apr 2007
I want to have a rotating image header which has to rotate in order. I'm using JS for this at the moment.
Thing is, I want to overlay a vertical navigation on the header image.
Now, I've got it working by defining the header.jpg file as the background in the CSS as:
Code:
#header{
height: 211px;
width: 780px;
background-image:url(images/header.jpg);
background-repeat:no-repeat;
and the HTML is <div id="header"><div id="nav">nav code here</div></div>
Problem is, this image is fixed and doesnt rotate.
So my two thought processes are:
Is there a way to make the images rotate using the JS script from the CSS file or, how can I place the navigation over the image using CSS whilst displaying the img src for the header in the HTML?
Rough Idea of what I'm trying to achieve here:
tried that and it forces the header to drop down.
I'm guessing I'll have to pull off some z-index and position absolute?
