Hello,
my build will be as follows:
i7 920 OCed
Rampage II Extreme
3x275's OCed or 3x280's OCed
(I have 3 of each and intend to test them both on Crysis at 1980x1080 with and without AA in order to decide which set to keep.)
From what i have read, RAM makes little difference to gaming performance, however the most significant factors in choosing RAM are the timings and latency, which is something i don't know anything about.
Apparently the frequency of the ram makes little or no difference compared to the latency and timings and overclocking ram or using ram at high frequencies just increases power consumption and heat for little gain.
Aside from this i have some questions about to use a 32 bit or 64 bit version of windows 7.
Basically i had read that Windows 7 32 bit can only address 3.5 GB of memory and that video memory is included in this.
So when i am testing my 3x 275's and 280's to see what's better could a 32-bit OS bottleneck gaming performance, as there would only be an extra 500 mb of system memory available?
i7 920 OCed
Rampage II Extreme
