Hello! I have a Lacie Ethernet disk(2 drive) running a via C3 800 cpu, what distro?
27 Dec 2002
In ** bottom drawer...
As above - i want to use the lacie as a file server/backup/sharing box.
Im aware the VIA C3 isnt a full i686 chip so not sure what Linux distros it will run...
Main things are I need the drives to spin down and the unit to sleep untill woken by LAN or scheduling for recording etc.
Any help appreciated!
Cheers,
Perry.
I had a Via C3 mini-itx board until last year. I ran it with ubuntu 8.04 (or a previous version i'm not 100%) using a CF card. I can also tell you Fedora 10 runs on it.
I know centos doesnt run and archlinux won't either.
Good luck, it's fun hardware despite it's limitations!
I run Debian on mine. It's perfect apart from the fact that mine only has USB 1.1, can't even max out my 50mb connection due to this limitation!
