Really need some help here, Im at my wits end.
Yesterday I started to get the dreaded "0x0000007B: INACCESSIBLE_BOOT_DEVICE" bsod message, each and every time I boot up (straight after the windows loading screen comes up).
Im running windows 2k, ide hd 160gb (five months old) with two partitions on it (aprox 120 and 40 gig each) larger bootable and a small one for junk , all on fat32.
Ive tried putting the HD into my gf's xp box(the one Im using now), the main partition isnt even recognised as being formatted, but the smaller one is and can be used as a normal slave drive. The bootable partition not being recognised could be due to the xp box using ntfs file system I suppose, but if thats the case then surely the smaller partition ought to have been unrecognisable also.
I tried booting from the win 2k disk and running chkdsk , but that just came back with "this disk has one or more unrecoverable errors on it" which wasnt much help.
I dont have a repair disk, and as I dont have a spare HD (or xp pro) I dont see anyway of making one.
Im really desparate here, any help/advice gratefully received
