Help!! 1GB OCZ EL DDR PC-5000 unstable at 1T
1 May 2003
I have some EOL PC5000, and I can only run the memory at 2T, as every time I try to run the memory a 1T, my system crashes, I would have though that this stuff would easily run at 1T as I am ony using the memory at 250, and not a 312 as it says it can. Here is my settings below as well as my system spec's.
I would be greatful if some one could help me out, and show me what I am doing wrong, so I can get some decent timmings, and at 1T :(
250
3
16/16
11
100
disable
auto
1.5v
1.325v
113%
1.3
1.6
2.8
200
disable
2.5 - will not run at 3
4
8
4
10
14
2
2
2
3
3120
auto
enabled
auto
0
Level 5
Level 2
8.0 Nano
Normal
5.0 Nano
128 Cycles
disable
16
7
Disable
A64 4000+ San Diego
DFI LanParty UT NF4 Ultra-D 6/23/2005 Final
OCZ 1GB PC5000 Dual Channel Platinum EL-DDR
ThermalRight SI-120 / 120mm Vantec Stealth Fan
HIS Excalibur X850 XT PE 256MB DDR3
Samsung SM-930BF 19" LCD Monitor
WD Raptor 74GB
Audigy 4 Pro
Pioneer 110DBK
Pioneer 109XL
CM Stacker Case
Antec NeoPower 480w
Logitech Z-5500 Speakers
Logitech Cordless G7 Gaming-Grade Mouse
Logitech G15 Keyboard
