Help 280gtx
22 Nov 2008
Will my psu run geforce 280gtx without any problems???
I have got :
Enermax Infiniti 720W
Core 2 Duo e8400
MSI Platinium P35 mobo
4 GB Ram ddr2 (4x1gb)
one HDD
Thanks
Just fitted a BFG superclocked version of GTX280 & it plays maxed out Crysis etc with no problems with my Corsair 650 PSU
Altho the 280 has the two imputs as mentioned above they both came with a splitter & needed two dedicated PCI-E cables into the 8 pin socket & two 12v molex imputs into the six pin & this gave me a minor problem trying to find an unused one & I ended up unplugging a rarely used hardrive.
I swapped out a 9800GX2 & the FPS difference is considerable
