- 21 Mar 2009
After 18 months of regular BSODs and system freezes, 1600 man-hours of fault testing/component replacement, I am finally ready to give up on my current Rampage IV Black with Windows 10 64 Bit.
I am looking to update to a Rampage Extreme VI Encore with a 14 or 16 core processor and have some simple questions:
Critical……..
Critical……..
- How well does this MB support Triple SLI? [There are rumours about stability issues and GC WB Clearance issues at the lower PCIe slot where many headers are located]?
- Is anyone out there running this with 3 x SLI EVGA Titan Black (Hydro Copper)? [Are they performing as expected]
- Is anyone out there running this with ANY 3 x SLI EVGA Hydro Copper GC which uses the same SWIFTECH Waterblock AND can you fit a Creative SoundBlaster ZxR above the 2nd large PCIe without fouling the GC Waterblocks, SLI Connector PCB & the ribbon cable to the additional soundcard daughterboard?
- Can a Asus ROG Enthusiast SLI Bridge (4 way) be adapted to fit the strange spacing on this MB with 3 x SLI?
- Has anyone had any good or bad experiences with a standard EK-Quantum Momentum or larger QM ROG Rampage VI Encore D-RGB – Plexi Waterblocks?
- Is it worth going for Quad Channel memory such as Corsair Vengeance RGB PRO Black 64GB 2666 MHz DDR4 (CMW64GX4M4A2666C16) or just two larger sticks
- Does this MB have issues with any particular 1TB M2 card or do you have any recommendations for a particular brand/model?
