Help 670 SLI vibrating screen
22 Oct 2004
Help, im getting a weird problem i tried running 3dmark 11 and vantage and the screen just seems to shakes. I tried running heaven benchmark and that does the same. It also crashed with a big red screen, which i could minimise and close.
EDIT: I disabled SLI and its fine. I dont think i got a faulty card, its the first time ive used SLI maybe im doing something wrong?
Even though it works fine with one card it could be a driver issue. Try uninstalling the drivers then reinstalling.
When I first installed my 680 I had a couple of red screens, the above method fixed it and it's been 100% stable since, worth a try for your 670's.
If that doesn't work try both cards independently to establish if the other one is faulty, hopefully won't be more than a driver issue though.
Ive already tried the drivers. How do i try the cards indvidually, do you mean take one out then try the other?
You could try put the other card in the same slot as the one that's currently working fine, to see if that works fine as a single card too. At least that would eliminate some possibilities, could be one of the cards is a dud.
Also might be another driver you could try, worth a shot if nothing else, but TBH not tried SLI myself so am no expert by any means.
