Help 775 MoBos
19 May 2004
Horsham, West Sussex
I'm looking at an Intel chip in the 'Market' but having had AMD upto now I'm bemused by the huge range of 775 Mobos.
I'm on a tight budget so looking for a mobo around the £50 mark.
The cpu is an E6850
Would this MoBo be okay
http://www.overclockers.co.uk/showp...P31 (Socket 775) PCI-Express DDR2 Motherboard
or should I being looking at something else - really confused by the different chipsets.
Also I will be keeping the same hard disk and don't intend to reinstall windows - is this likely to be okay?
Cheers,
Nigel
