Afternoon all,
This is driving me mad, i've been running this card since Day 1 on 3 monitors, it's ALWAYS pulled 120W idle due to the Vram not downclocking, research at the time said that they were gonna fix it on a driver, still no fix.
I put some research in again as it makes my room so ******* hot even when just watching youtube or whatever whilst working, this research said it could be cables, some cables are **** and tell the card to throw as much at it as possible just for compatibility issues, i update my cables to some decent DP2.1 ones from UGreen. Same problem.
More research, they then go on about changing the blanking rate, i went through this method and makes ZERO difference.
I then think, maybe it's pulling too much data, so i lower ALL off my 1440p monitors to 6bpc, 1440p @ 60 - as this should pull less data from all 3 than my main monitor on its own running 10bpc, 1440p @ 240hz. Same problem.
It literally means i can't have a third monitor connected if i dont want my GPU to be used as a storage heater, let alone the extra £2/week its directly costing me.
Anyone have any dealings with this? I'm sick of it in all honesty.
Help is greatly appreciated.
