Help a mate freezing problems with new computer
24 Oct 2005
North East
I have a mate who bought a new comp recently and its great he said but he is having these kinda freezes where sound still plays in games etc but no input from keyboard or mouse is happening so he cant alt and tab or close down things in task manager. Its not allways in gaming i think he said and happens a lot on the desktop.
Here is a post i asked him to make where i would post it here. It explains it more his way.
The problem.
The pc randomly locks up. When it does the mouse&keyboard stop working and the OS's freezes like a screenshot. This is totally random usage could be 2hours of heavy use or 2minutes of idle desktop. However games (GRAW/Quake4 and Obliv) work fine, even after a lock. Sound and the game will continue but of course no control as kb&mouse locked.
The PC.
It is a pre-built system with no windows install orignally. Nothing is overclocked.
AMD 64bit 3800+ (2.40ghz) Venice Core
ASUS M2V motherboard
1024MB Samsung PC3200
Samsung SATA II 80gig HD
Onboard Real Tek HD soundcard
ASUS Geforce 7600GT Extreme on asus provided 84.21 drivers.
400w PSU
NEC 52x/DVD 16x Rom drive
What I've done.
I installed my own copy of windows Home sp1 then updated to sp2. I then installed my provided drivers with my motherboard, VIA, cool and quiet. May edition. I then installed my old 80gig Western Digital IDE drive. I then started encountering this problem. I took out the HD which was set to single, the orginal system untouched. Formatted and then installed Windows Home sp2 (borrowed) onto the SATA drive. Same issue continues. I've installed with all update drivers on motherboard, via, graphics, sound and Mouse (ms optical 1.1) no change. I've formatted and tried without drivers execpt the sound and mouse, less frequent but still happens. I've tried unplugging the mouse and the keyboard (a different times of course) swapping the mouse, putting the mouse in the USB(this is with and without the keyboard plugged in) No change will lock randomly. All cpu temps are fine screenshot check attacthed DXDiags
Here is a dxdiag of his comp
http://www.mysharefile.com/v/8904621/DxDiag.txt.html
Here is a speedfan report
About speedfan his +5 volts is a bit under the normal 5.0 range so i thought it maybe a psu power issue as its a 400w psu.
I did think it maybe a number of things. Such as poor psu and is causiung the freezes. It could be a faulty motherboard perhaps. It could be not enough volts on cpu or just incorectly configured in bios. Then a memory problem as memory can cause lockups like this.
CPU Z info:
CPU-Z Report
CPU-Z version 1.35.
CPU(s)
Number of CPUs 1
Name AMD Athlon 64 3800+
Code Name Orleans
Specification AMD Athlon(tm) 64 Processor 3800+
Family / Model / Stepping F F 2
Extended Family / Model F 4F
Brand ID 4
Package Socket AM2
Core Stepping DH-F2
Technology 90 nm
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
CPU Clock Speed 2399.8 MHz
Clock multiplier x 12.0
HTT Bus Frequency 200.0 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2399.8 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 128 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model M2V, Rev 1.xx
BIOS vendor American Megatrends Inc.
BIOS revision 0302
BIOS release date 05/24/2006
Chipset VIA K8T900 rev. 00
Southbridge VIA ID3337 rev. 00
Sensor chip ITE IT8712
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory
DRAM Type DDR2-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 266.6 MHz
FSB:DRAM CPU/9
CAS# Latency 4.0 clocks
RAS# to CAS# 6 clocks
RAS# Precharge 6 clocks
Cycle Time (TRAS) 18 clocks
Bank Cycle Time (TRC) 26 clocks
Command Rate 2T
Software
Windows version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
DirectX version 9.0c
Hope someone can help.
