Hi all, I'm new so go easy.
I am looking to get a new system. Budget is ideally £500 maximum, but could possibly go more if need be. I am fairly clueless when it comes to spec'ing my own machine so looking for some help really. I only need the tower as I already have Monitor, K&M etc.
It needs to be able to run ArchiCAD 16 which is some 3D Architectural design software. Some requirements are below:
Not too demanding but with all these things the better the spec the better it will run. Not sure what to look for in terms of graphic cards and the like though.
I would also like to be able to upgrade the system too so that it will last me a while.
It would also be cool if it were capable of running FPS games such as Battlefield 3, although this is not a must (I'll stick to the xbox) it would be a bonus if I could get a machine that is capable within my budget.
Any suggestions on bundles, helping spec my own system, links or otherwise will be appreciated.
Thanks very much
Craig
Intel® Core or higher required.
64-bit processor required.
Multicore processor is recommended to exploit ArchiCAD 16 performance capabilities.
With 64-bit system: 3 GB RAM is required, 6 GB RAM or more is recommended.
Thanks very much
Craig
