Help a noob out
23 Nov 2004
UK
Right will try to keep this as simple as possible [ mainly due to not knowing what i'm talking about ] I have 3 external usb drives full of movies 12TB,14TB and 16TB connected to my media/gaming PC. I want to be able to watch these on the TV in the living room. TV is connected to the same wifi network. What do I need to do to get this to happen?
What make/model is the TV?
A Jellyfin server on the media PC and the client on the TV (or a firestick or similar attached to the TV) is one potential way to go.
So it looks like Samsung 6 TV's need the Jellyfin client sidelining in to it or to try loading it on to the fire cube.
If the app shows as available in the available apps search (does on my fire sticks but have read the fire cube has previously not supported it whilst sticks have at the same time) then that's an option, otherwise I guess you are waiting for other easy to deploy options compatible with the TV or Cube.
Edit: Samsung's "Easy Connection To Screen" might also be an option but don't have experience with that
