Help a noob Overclock
Don
23 Oct 2005
North Yorkshire
Hi guys,
Firstly, the screenies I have below are not what I'm running, I did have a stable 4.3 ghz but wouldn't mind trying to get to 4.5/4.6 really.
After following a guide I have come to the conclusion these should be my settings, however, I have no confidence in my ability so wouldn't ever put them into play without asking the Pro's first.
So, what should I amend, I think the voltages are pretty high?
Haswell 4770k
Gigabyte X870C
H100i
Don't ridicule me please :D
Cheers
No, I just went with the setup in the end and it blue screens ont he combined test on 3DMark11. This is far as I got as I'm not always at the house where the PC is present.
What would you recommend I change first? The temps seem ok so not sure I want to up the voltages anymore?
never try prime it is a bad program the only stability test you should do is to use it as you normally would this is the best stress test of all.
Try looking in the ask 8 pack section of this forum as he has some good advice and if that does not work try posting in that forum and he can help you.
