Caporegime
- 21 Jun 2006
basically i have a tai chi case with built in water cooling
http://forums.overclockers.co.uk/showthread.php?t=17513488&highlight=tai+chi
this thread should help you get started in helping me apparently tubing is 6mm dont have any more info other than that which may be wrong
i dont care about money and i dont wanna build a custom rig just upgrade this one as long as i get the best performance, im thinking a new pump? people have mentioned having more than one pump, how would this work? might change the waterblock and fans, etc will be used for cooling a conroe, also would help if you showed some pics or made little very basic diagrams or something, also if you just named me parts if they cant be bought here i will be able to source them
also what are barbs?
would i need to buy more tubing? im looking to cool the cpu only and how would this upgraded system compare with a titan amanda?
