Help a noob:
31 May 2005
Alfreton,Derbyshire
When I say noob, i really mean it. I have just bought my parents an LG RH7900 DVD recorder, and they would like to get a surround sound system to go with it. It has optical and coax out for audio.
What am i going to need to get some 5.1 surround sound working for it?
Can i connect the audio out straight to a 5.1 speaker set? Do i need to get a 5.1 system with an amp and then connect to the amp?
What sort of cost will i be looking at? Don't want anything fantastic
Any help appreciated!! :confused:
You'll need a set with an amp, which all but some of the PC based ones should have. Of course by having an amp you want one that has a remote control so another reason to avoid some of the PC based ones.
Next set a budget and folks can make some suggestions
