Help Accessing Airport Extreme Remotely?
8 Nov 2012
I have an Airport extreme base station at home and want to be able to login and admin the router from remote locations. I have logged into the router and set the checkbox for WAN access but this doesn’t seem to help.
All other routers I have owned you are able to login to them from your WAN IP address and then play with the setting s. When I launch the airport utility from outside my home it doesn’t find the base station, same with iOS app. What am I doing wrong, or is this even possible with the AE?
Cheers
