HELP - Adobe CS3 Error
Status
Not open for further replies.
5 Dec 2006
I keep getting this error when I launch any Adobe CS3 software:
Licensing for this product has stopped working.
You cannot use this product at this time. You must repair the problem by uninstalling and then reinstalling the product or by contacting yout IT administrator or Adobe customer support for help.
I have reinstalled THREE times and I have also done the steps listed on the Adobe website (HERE) FIVE times.
I've used the same DVD several times before, on Vista 32bit. But now on Vista 64bit, it just dosent work.
Any help is appreciated.
Thank you.
OK, according to THIS WEBSITE.....
"C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe"
....Needs to be version "11.3.5.1" - But i have version "11.4.100.0"
This screenshot explains better (Click to enlarge):
So if someone can please send me the proper version files from their setup i will be extremely happy!
is it a legitimate copy pirate copy
? you got the latest crack? patch etc, try re dling a newer version.
(If you still haven't figured it out by 3pm today I'll have a bash at installing my cs3 copy on vista 64. it worked fine last time i used it, but it's on a separate hdd and i'm too tired trying to get it off now.)
Ok, now i'm completely ****ed off.
Spent 2 hours formatting and installing a fresh copy of Vista 64...
...install CS3 on a CLEAN VISTA and...
...yep, you guessed it, same ******g error! :mad::mad::mad: :rolleyes::rolleyes::rolleyes:
AND now the adobe help site is ******g down, so i cant even follow the help instructions :rolleyes::rolleyes::rolleyes: :mad:
Status
