- 20 Oct 2007
Hello, please i need some help. I dont know what i did.
First i tried to use Ati Tools, i was moving the sliders etc, but i could not control the fan so i left it.
Then i tried riva tuner, here i could control the fans so i though it would be a good idea to use riva tuner to speed up the fans a little bit and the usual CCC Overdrive to overclock the gpu and memory. Not only that, instead of using a fixed speed of lets say 80% I trusted on the auto mode.
Well, that did not work right instead of speeding the fan up it did just the oposite, i thing they were running just at minimum or maybe stopped.
I tried to overclock the card, then you guess what happened? yes. Black
Then i rebooted and after a few seconds my system was freezing like a 360.
Then i rebooted again and ... freezing and i started to worried.
I rebooted in safe mode, hey... it seemed to work again. Needless to say i got rid of riva tuner, ati tools. first uninstallint then deleting whatever i saw on c:/program files related to this.
Not only that i reinstalled the drivers.
Now everything seems to work right but one thing, catalyst control center wont open.
I am wondering what is the problem. It might not be the best card tunning software but hey, it is the oficial one, and the one i want to run when things do not go well. Like now.
What can i do?
Oh i must say i can see CCC.exe in the task manager.
What can i do?
