I had a previous topic and it turned out the motherboard was faulty.
So I got my new replacement and put it all together, the motherboard kept going in a reboot cycle.
Looking at some forums and It looked like the ram voltage, so I ordered some new 1.8v ram from here.
The new ram came and I thought all was good, It went into the bios but then it just froze up. I haven't managed to get into it since, even with chmos reset's etc.
Another faulty motherboard?
I've tried all my ram sticks, total of 6 and none of them work, my PSU has been used while I was waiting for my replacement mobo and it worked fine, graphics card has been tested. Only other thing I think it could be is cpu.
If it's faulty can you recommend another x38 board.
Thanks
Thanks
