- 18 Mar 2012
- Eastbourne
Where do I start.. Well I got given a gigabyte motherboard from someone on here, I went and got it, popped a CPU in and all other relevant parts and it fired up fine first try, installed windows, great! I turned off the PC, boxed it all back up and left it until I could afford to get a case to out it in. Got a case, put it all in, fired up fine but no display and only one of two fans spinning.. Popped the card into my PC, fired up fine! So I thought the psu may have been the culprit, got a new psu off the MM and put it in today built it out of the case and still nothing from the second fan. I have a spare motherboard that I tried it all in and it works fine in that.
So I'm guessing it's the motherboard that's at fault here, any ideas to why it would suddenly stop working? You can see all the fans spinning up, h55 pump start to work just no second fan on the gpu. I'm baffled to why this has happened?
I updated everything apart from the bios when I had it running first time as I didn't experience problems or anything so thought it would be fine!
