Help again..
20 Apr 2012
Ive got an external USB dvd drive so I can install Windows. Changed the boot device, get into setup and it asks me to select driver to be installed. So I click on my drive (that if u expand it clearly shows the windows files there) it says no drivers were found.
Thanks
I'm guessing windows 7? If so, make sure its not plugged into a usb3 port, try a usb2 or lower and/or another port.
Failing that, I would suggest buying a usb stick (you dont need much space so should be cheap and no need for it to be usb3, or you could have the same issue), download the version of windows you are after (available from ms if you have a valid key I think, possible else where too) and then use rufus or similar to create a bootable install on the usb stick. The install is likely to be faster too, and much easier for future if needed.
