Help an Idiot Use a Multimeter
19 Nov 2004
Wokingham
I am reasonably competent with most things but electronics is beyond me. I've got a 40A circuit breaker in my car that I suspect is faulty and therefore the heating in the car is not working (Mk3 Supra). I bought a multimeter but have no idea how to check if this CB is faulty or not. Any help would be greatly appreciated!
Check the manual and test for continuity across the terminals. It should look like a little speaker normally.
Then touch each probe to the terminals at the same time and you should hear a noise if the CB is letting current through.
Bit different to mine - but the three main things you'll use are from left (clockwise from off).
1: Measure DC voltage.
2: Measure AC votage
3: Measure resistance + buzz if there's a connection.
#3 should be the one you're after to test you're getting a connection through the breaker. You can test by touching the probes together - should get a buzz.
Thanks guys, I set it to #3 to measure resistance. It buzzes when you connect it to each terminal on the CB, which means I guess current is getting through?
If so, check your manual again and test the wire coming into the CB to see if that's getting current. If so, start checking upstream for faults.
If not you'll have to trace back and see where it's failing. I'd also look at switch wiring as another obvious point for failure. Especially if you can pop those out from the dash easily.
