Help an idiot
27 May 2012
Hello folks, i'm finally taking the jump from VGA to DVI (about time)
As such I am now boggled.
What DVI cable do I require to get the best use out of the following;
XFX Radeon 7850 2gb core edition
BenQ GW2250HM 21.5" dvi monitor
(I had no idea that there were so many different dvi cables)
Any DVI cable will do. You only need a Dual link one if you're doing resolutions higher than 1080p. Did your monitor come with one?
If you're using external speakers, no. HDMI and DVI are exactly the same, just HDMI being able to carry sound.
This cable will do, but you can find cheaper ones if you search else where.
