Hi all, i'm in the process of building my first PC, but despite what everyone has told me, it certainly is not simple. I'm apparently more mentally challenged than I thought.
Yesterday I had a nightmare fitting my Alpenfohn K2 cpu cooler. Even though I now have this in place I'm unsure of the connections. I've put the 2 fans on the cooler and then connected the 2 fans with a 2-headed 4-pin connector. Now, I'm fairly certain I then connect the other head to the 'CPU_FAN' header. However, there's what the 'instructions' call a Low-noise adapter (7v) which I can't fathom if I need or how I would connect it.
I've just looked at my Superflower Leadex 750w gold psu and found that I've been given a foreign 2-pin plug rather than a 3-plug. Can I get a standard adapter or will it need to be a special one, or should I return it?
My Corsair Carbide 500r has 2 front fans which are connected to the front panel fan control. The cables then go from there and come out by the motherboard as (i think) a molex connector and a 4-pin connector. There's then a rear exhaust fan and a side intake fan which both have 4-pin connectors. Any ideas how I hook all these up correctly.
I'd really appreciate any help.
