Hi All,
This is my first post and after seeing all the excellent advice given on this forum I’m hoping that you can help me.
I am thinking of upgrading my present system as it is now a little long in the tooth. My budget is £700. I have selected the components which I have researched and have received good reviews.
The following is my present system and the system I would like to upgrade to:
Present System
1 x Asus P965 “Commando” gaming Motherboard Socket LGA 775, on board 7.1 Surround Sound
1 x Quad Core Intel Core 2 Quad Q6600, 2400 MHz (9 x 267) CPU
1 x Zalman CNPS9700-LED Super Aero Cooler for CPU
2 x 2GB OCZ Reaper 800Mhz DDR2 Ram
1 x Nvidia GTS 250 1Gb Memory Graphics Card
1 x Seagate Barracuda 160Gb 7200rpm SATA Hard Drive
1 x 850W Avenge Power PSU
Upgrade System
Asus P6X58D-E Intel X58 Socket 1366 DDR3 Motherboard £149.99
Intel Core i7 950 3.06GHz 8Mb Cache LGA1366, Retai... £225.00
Thermaltake CL-P0564 FRIO Intel LGA1366/1156/775/ CPU Cooler £37.59
Palit 768MB GDDR5 GeForce GTX460 VGA / DVI / HDMI ... £122.52
Corsair 4GB (2x2GB) DDR3 PC3-12800 1600MHz C9 Dua... £51.99
Antec TP-650 TruePower New Series Modular 650W Pow... £66.08
Samsung SpinPoint F3 500GB 7200 SATA 3GB/s 16MB Cache OEM £32.75
Total £685.92
All the above components are priced from Overclockers and seem to be very competitive with other dealers I have checked with.
I have two questions:
1. Do you think this is a worthwhile upgrade for the money? I welcome any suggestions as to whether you think there are better value and performing components that I have chosen.
2. What would you think is a fair price for my old components which I would like to sell after upgrade to help offset the cost of upgrade.
I look forward to your comments and would like to thank you in advance for help.
Robocat
Present System
Upgrade System
Total £685.92
Robocat
