Help another DS4 user
16 Oct 2003
Trying to install Windows on my new DS4 build (bios F5), have loaded the RAID driver when Windows asks for it. Setup hangs on the "Setup is starting Windows" message on the bottom left of the screen, and after staying there for up to 5 minutes it BSOD's with the message "PROCESS1_INITIALIZATION_FAILED."
I'm using 2x1Gb Geil DDR2 800 sticks, have tried using just one of them and in a different socket. Is it a memory error or maybe down to my RAID setup, or what?
*edit - this time round it has just complained about the more common UNMOUNTABLE_BOOT_VOLUME if that helps.
Well there you go. I discovered it by fluke. I first tried installing off my other optical drive but for some reason it wouldn't see that drive - then I realised the two optical drives, plugged into the one IDE slot, were both set as master :o
So I fixed that, now it's just proceeding to format as a type.
\o/
