hi ,
i have problem with the 920 cpu cooler , i sure did everything like the manual said when i build my mobo , when i fired up for the first time i received a msg said " cpu fan error " , but then it keep on loading windows anyway ,the cooler seems working , and when i try to install the driver and software from dvd for that cooler , a msg pop up and say cannot connect to chill control device ,check usb connection on device and restart the chill control application .
when i open device manager under the universal serial bus controllers ,theres yellow triangle which said unknown device ,i belive is the cooler . worry that without the control it will fry my cpu , please help ,
my mobo spec
asus crosshair fomula v motherboard
kingston hyper x 16gb
asus geforce 560 ti direct cu2 top
corsair 850w
amd bulldozer fx-8 eight core 8150 3.10ghz
antec h20 920 cpu cooler
my mobo spec
corsair 850w
