maybe anybody bought this power supply and know is platinum or gold rated? Thanks
http://www.overclockers.co.uk/showproduct.php?prodid=CA-238-AN
^^ and I thought you'd say gold!
confusing official site don't have this model only gold, but store have just not available...
The gold is old and EOL.
Replaced by the Platinum verison. I will get the Antec site updated.
Thanks you! order made
And the HCP 750w Platinum is now on the Antec website
Excellent, will post my first impressions tomorrow my old cooler master m700
5 years old served me well, just started make some noise, warranty ended I hope picked best of best and forget for up to 7 years
I am sure the Antec will serve you well. The OEM is Delta who are probably the best in the business.
Correct, our products are not the cheapest in the market, but we offer the 'best of the best' in terms of quality especially with our DELTA made units, they can be considered expensive, but my god they will outlive every other component you own by up to 10 times.
Our PSU's are some of the best, if not THE best consumer PSU on the market, because we work with DELTA to ensure only the best components are used in our products and we have a unique socket connectivity method, whereby our motherboard 24 pin connect actually has a 28 pin connection to the PCB design, and the 4/8 pin cables are connected to the PCB by 16 pin connectors too, this technology is unique to Antec and offers the best in safety, regulation etc.
So we are not just another vendor labelling an OEM standard product with an Antec sticker/badge we actually offer innovation and quality which is difficult to match.
