Looking for help to enable upstairs PC running Steam/Discord/YT etc online, and downstairs to play Steam offline by manually disabling network in Device Manager-which is currently the way it's done.
Can you make dektop shortcuts to bypass Device manager?
Any guides/scripts/bat files/right click desktop to enable/disable network shortcuts that can make life easier?
Thanks in advance.
Thanks in advance.
but f its disabled renable, else disable it
