Hi,
I've been reading some of the posts here, and the FAQ etc.
Last night, i OC'd my rig (Asus P5N-E, Core 2 Duo E6320, 3GB Kingston DDR667) to 1600FSB, 733DDR, with 1.425v Vcore & 2.185v Vdimm.
After this it wouldn't POST. It doesnt even give me the Asus logo as usual. Normally when an OC fails after a few reboots it restores to default values and boots up so you can change settings. This isnt happening!!
I've tried turning the power off, disconnecting PSU, leaving PSU disconnected for 1hr, i then tried using the ClearCMOS jumper. None of this has worked!
Is there any way i can reset the configuration settings to default to get the board to boot again??
Thanks
Matty
Thanks
Matty
