HELP! Asus p5w Overheating!
10 Sep 2006
Hi,
Just got my Pc a few days back on got it up and running smoothly only to find that the asus "pc probe" software is reporting @ 50c :( the motherboard is a asus p5w DH Deluxe with a intel dual core 6600 CPU
Does anyone have this problem ? Is this too hot for the motherboard to run ?
Any help would be greatful,
Thx
No real probs.....as he said ^^ :)
I took off the heatsink (as many others have) and cleaned it up, applied fresh AS5 and then reseated it and temps now hover around 40-45 (even sat under one of my x1900XTs) ! Can do the same for the NB if you feel brave enough ;)
