- 13 Oct 2006
- Surrey
Right my screen began to looked washe dout so i decided i'd try and reinstall the display drivers.
I removed them from the device manager, and cleaned using driver cleaner.
I then tried to install the drivers and during the installer it says the there is a driver detection error or something and then it says theres no hardware to install.
Whats more annoying is when i boot back into windows a box comes up telling me that my drivers are out of date even though they're meant to be removed!
I'm really struggling here, is there any way i can remove all traces of ATI from my system manually?
Thanks
Thanks
