Ok running quad core amd 3.2 be 4gb ddr3 and a 1gb 4870 and im just fed up with poor frame rates in Bc2 .
With fraps it can be running 70+fps and then drop to as low as 14fps . got most of my settings on low . forced to dx9 ..bloom etc off . Everything in cats to performance and latest drivers . Even have a mild overclock on the card but to no avail .
So OCUK tell me whats a cost efective upgrade . i play at 2048x1152 (23" sammy) single screen . air cooled so want quiet (ish) but no fussed about having everything max (no dual card setups)
Games wise it will be wow/bc2 and most modern games .
Spec me ocuk
And thanks in advance
Persil
Spec me ocuk
Persil
