A relative has asked for me to help them beat this spec for a similar price. £450 absolute maximum.
Thanks.
screen mouse keyboard and os not required.
Item Features:
•AMD Piledriver FX6300, 6 Core Processor / CPU running at a blistering 4.0GHz!
•8GB DDR3 1600MHz RAM
•AMD RADEON HD7750 Graphics Card With 2GB Dedicated DDR3 Graphics Memory
•1TB 7200RPM SATA Hard Drive
•CD / DVD-RW Dual Layer Optical Disc Drive
•Gigabyte GA-78LMT-USB3 Motherboard (Full specifications of this board can be found here)
•High Quality Vantage RED Desktop PC Gaming Case with 3 x RED LED Fans
•SD Memory Card Reader Built Into Top of Case
•650 Watt Quiet Power Supply Featuring Large 120mm Cooling Fan
•Gigabit Ethernet 10/100/1000 Mbps LAN
•2 X Ultra High Speed USB 3.0 Ports on Back
•4 X High Speed USB 2.0 Ports on Back Plus Further 2 On Top
•8 Channel HD Audio
•6 X SATA II 3GB/s Ports
•1 X IDE Port (Supports up to 2 devices)
•1 X PCI Express X16 Slot
•1 X PCI Express X1 Slot
•1 X PCI Slot
•1 X PS/2 Port (For Keyboard / Mouse)
•1 X VGA Port
•1 X DVI Port
•1 x HDMI Port (With Audio)
•Dual Monitor Support
•UK Mains Cable Included
•All Relevant Driver Discs Included
•PLEASE NOTE: An Operating System is not included with this PC.
Thanks.
Item Features:
•8 Channel HD Audio
•1 X PCI Slot
•1 X VGA Port
•1 X DVI Port
