Trying to overclock 2 6970's in crossfire...
I got a decent overclock on cores at 960mhz with 1.250 volts. However for the life of me I can't overclock memory if I raise the memory by only 5mhz from stock the scores in heven drop??
Now as I take it of scores drop it means there are errors in the memory which the frame has to be sent again taking longer and hence causing a lower score??
The benchmark does not crash or artefact...
Does this mean my memory can't be run above stock??
How can I overclock memory??
is there a limitation with crossfire overclocks??
