Hi, i have overclocked my PC from a standard 2.2Ghz (3700+ SD) to a 2.7Ghz using a 333 divider with 2X1GB Corsair Value Select ram. I am using a Antec Sonata II case with 1 x 120mm fan. My idle temperatures using the standard AMD 3700 HSF are:
CPU:42
Chipset:33
My temperatures on load (Prime95 2 hours) are:
CPU:51
Chipset: 36
I think these temperatures are a bit high for my liking. What coolers/fans do you recommend i should buy from OCUK? (Low noise). I am not looking to spend more than £35 including delivery.
CPU:42
Chipset:33
CPU:51
Chipset: 36
