Right, I have read and read and read and still can't make my mind up as to which card to upgrade my system to so time for advice.
Currently have an X800XT which has been fine for the games I have been running since I only run at 1280 x 1024 res.
However, I now have two games (splinter cell and colin mcrae dirt) which I am desperate to play but they require Shader 3.0 support so time to bite the bullet and upgrade.
Unfortunately money is tighter than it used to be when I bought the X800xt for £350 (was I mad?????) so as much as I wish I could have a 8800 GTX its beyond my reach plus would probable need a psu upgrade as well
So the best I can bring my selection down to is as follows:
X1900 XT 256Mb - £95
X1950 XTX 512Mb - £105
8800 GTS 320 Mb - £160
2900 xt 512Mb - £185
There would appear to be no real mid range card anymore. I have already discounted the 8600 and 2600 as although their performance would be a step up from my X800XT (barely any fps with the 2600, all I would be gaining would be the shader 3 support and IQ). The directx 10 support is irrelevant IMHO as neither of these cards will be able to run the new games at any kind of playable framerate.
So my choice comes down of what used to be the old top end and what is now the bottom of the new top end.
So do I get one of the x19xx cards which would give me my shader 3 support and a very large fps gain over my x800xt and then upgrade again next year or should I stretch myself to the 8800 or 2900 now?? As far as I can tell, the 2900 would give me better image quality but no more fps than the x1950xtx whereas the 8800 GTS would still give me even more fps for my money. Also confused with the 8800 GTS 320Mb, as in certain games it's results are dire due to some problem over the memory. Hopefully, only a driver issue with the weird quantity of memory but it might be a permanent glitch and with the new drivers improving the performance of the 2900 XT all the time and 512Mb on board, it might be worth the extra for the 2900 XT
The current price difference between the 2900 and 8800 would steer me more towards the 8800 atm if it wasn't for the memory issue.
But is it worth the extra £55 for the 8800 over the 1950 in the first place???
Are there any games coming out which require shader 4.0 support? I don't want to buy a shader 3 card and then have to upgrade again just to play a game.
God, i'm sure choosing pc components used to be easier in the old days!
So give me your best advice please
