- 7 Mar 2009
- Leeds
On startup it says before the windows logo that Boot MGR cant be found press CTRL ATL DEL to restart...now ive tried to fix the issue with a windows 7 recovery disk, and ive tried using a program called Easy BCD but nothing is working...any thoughts? or am i just going to have to do a fresh install. Interestingly, the recovery disk says it can find no errors.
Also, with the disk in the drive, if i let the "press any key to boot from cd" option time out then i can get into windows, without it in the drive i get stuck at the Boot MGR not found bit..
Thanks in advance for all your wisdom!
