Hi
I hope someone can help.
I have the syatem described in my sig below. It is slightly overclocked to 3Ghz on stock air and seems fine... however when I run software about 10 minutes in it sometimes hangs, or goes to a full BSoD. I have noticed if I am watching Media player on full screen after about 10 mins (sometimes) it drops back to normal size. I have run Memtest 86+ for 6 passes with no problem (I haven't overclocked the memory (yet)) So I don't think it is the memory. Any ideas, I feel it may be something calling up either in Windows (I'm running Xp Pro by the way) or some other running programme.
Thanks
Thanks
Not super chuffed as you can imagine. Is there a CPU test in DOS like Memtest so that I can rule out a dodgy install of windows?
