Last night whilst sitting at my computer, listening to a bit of music my computer restarted without warning. This happens quite a lot but usually it's not a problem. It'll just start up straight away and work fine again.
But this time it's refusing to post and when it happened i could definitely smell burning. I turned it off via the PSU and left it for 5 mins then tried again. This time it's posted fine and i've gone straight into the BIOS to monitor my temps but it's then turned itself off again and it's now refusing to post.
I had a similar problem when building it whereby the CPU cooler screws were touching the mobo tray and shorting the whole lot but i never got the smell of burning.
I usually keep a close eye on my temperatures to check everythings not too hot and they're usually very good. Around 40C for my CPU and around 35C for my system temp. When i booted into BIOS the temps were 42 and 35 which doesn't sound too hot to me.
I'm in desperate need of some help as there is some work on my computer that i urgently need to recover and work on. If anyone could give me the slightest indication on what could be burning and what i should look for i'd be very grateful.
Thanks
Spec: 6300 @ 2.8Ghz, 2GB Geil, DS3, 1900XT, Tuniq Tower, 3x Noctua Case Fans.
Thanks
