Was thinking to upgrade to 6970.
i noticed that asus do
-ASUS 2GB RADEON HD 6970 DIRECTCU II
** Image removed as hosted by competitor **
-And just the original ones
i read that directcu means they are better for cooling, and it actually isnt much more expensive.
how much better is directcu II, would i notice the difference?
it would be going under the pressure of many 3d programs such vue9 and maya and of course the stress of very demanding games *battlefield 3*
it should fit into my case and fit my motherboard yeh?
crosshair v formula
haf 922 (longer and wider than haf 932/hafx)
thanks in advance
crosshair v formula
thanks in advance
