Help buying a blender/Juicer
9 Aug 2007
Hey I really need to get a new blender and need some help. My old one struggled to get through the harder fruit/ vegetables and ultimately broke.
Has anyone got any idea my budget is about £100 ish.
Cheers
Have you looked up the Nutri-Bullet?
I'm not sure what the price is but it gets good reviews.
Its a very powerful machine.
Agree with Raymond, they're very different items, you need to decide what you want. I've got the Philips that he linked, and I've been really pleased with it, great piece of kit, although I was a bit upset to realise how much fruit it takes to get a decent amount of juice! :p
Tip, use Carrots as a base. They are cheap, low in calorie, healthy and quite juicy.
Thanks for the responses guys.
Sorry about being vague. I want to be able to blend both fruit and veg not just getting the juice and losing the roughage.
Yep i always used a lot of carrots, they go well with most fruits too.
Both products look quite good. Its a hard decision. hhhmm
the nutribullet looks good but just also found the vitamix. The only draw back is the cost. So I'm thinking maybe the bullet.
We had the bullet but found that it was a little underpowered and didn't blend enough at once.
Moved to the Vitamix 300 (£499- & that's the cheaper one!) and found that it's much better. Easy to clean and will blend amazingly well. Recommended :)
I have a bullet,its awesome.I freeze fruit and blast it with soya milk/nuts and a little honey.Strawberry/kiwi/mango and banana.Smoothie heaven.
Porridge oats, dark chocolate, banana, dried prunes, walnuts, broccoli, carrott, spinach, coconut milk/cream, water, spirulina :D
Ninja here.
Used almost daily.
Bullet is a little weaker in comparison from a motor stand point but they basically do the same thing.
Costco sell the 'will it blend' blenders. Seen them for 300 quid before.
I got a magi mix from John Lewis for 159, worth paying the extra. It's a food processor so good for other things. Blends frozen fruit no problem as long as you hold the lid down hard, otherwise you'll have 20 mins of cleaning to do.
