- 26 Aug 2016
Hi, I am looking at getting a new gaming pc, link below should give you my selection. Please can I get some opinions for whether this all works together, does it need the soundcard, and is the disc reader compatible? I primarily play WOW (some steam games and skyrim mods) and I need a system that can play it in ultra with 60fps+ while rendering the deep purple and green colours as well as smoke effects that appear to slow down my current system so much. It would also be fast enough to run Windows 10 updates in the background while playing. This spec is around £1100, which is my budget, I will also be using the pc for general web surfing, movies, work etc.
on board sound is now adays leagues ahead of what it once was.
