- 16 Dec 2010
laptop had a dedicated graphics card (6990m) which is switchable with intel hd, however after trying to switch it to the dedicated one day the screen flickered and it didn't reset. however on restarting windows i could not get into windows it would go starting windows then black screen but the power would stay on however the HDD led would go off. the only way to use the laptop on intel hd was to start in safe mode and disable 6990m. after getting back into windows and trying to switch back to the graphics card using catalyst control centre the screen turned black again and the hdd led went out.
i have taken the graphics card out cleaned it applied new thermal paste and put it together however still no luck. i reinstalled windows 7 installed the drivers. rebooted after installation and could not get into windows. i went into safe mode and disabled it and booted find into windows. however when trying to switch to the 6990m it black screened again.
i have ran out of ideas what to do next is there something wrong with the graphics card? or is there something wrong with the pcie slot? or the power to the graphics card? BTW the fan still works on the graphics card fine. would it be worth taking the laptop to pc world with a £50 charge and to see if they can diagnose the problem?
