Help! Can't get MS wireless 360 wheel to work
18 Jun 2005
So picked one up today and can't seem to get my 360 Elite to recognise it.
1. Put PGR3 disc into 360 (this has drivers for the wheel and cover of cd says to do this first).
2. plugged pedals into base of wheel, and wheel into mains.
3. Turned on 360.
4. Green light comes on at base of wheel (beside small white button)
5. PGR3 game starts.
6. Go into menu and select wheel as default controller.
7. Press centre X button on wheel, green ring around button lights up and rotates half a dozen times, then starts flashing (like what happens when you start 360 with gamepad), but it stays flashing. I would have expected a quadrant to stay lit permanently. Same things happens if you use press and hold down white button on base of wheel.
8. All buttons on wheel are unresponsive.
I'm either doing something wrong or the Elite is not compatible.
Can someone help ?
<doh>Am just after realising there is a small button the 360 you press to wirelessly connect new devices</doh>
I think the entire nation forgets about the 'connection' button!... :)
Hope you enjoy the wheel, I really rate it, especially in Forza 2
i think it also needs to be on controller port 1(turned on before any other controller using the big xbox button) and make sure it is on before you run the game. The wheel is superb with PGR 3 and even better on 4, but it is difficult....well for me it is :)
