Help ,cant get my pc to find my quest
24 Jun 2004
Carnoustie
Hi ,ive purchased a quest and would like to link it to my pc for gaming .
I have the appropriate wire ,but for the life of me I cant get the pc to find it ?
Any ideas please
Have not got the quest myself only the Rift but i think you unplug quest,install drivers/maybe restart THEN plug in quest
Also some usbs are picky about the headsets
yeah I cant seem to get it to go any further
Is there something I can do for the usb part on my pc by any chance .
It's weird. I got it working after this thread made me do a search and connecting up the quest then running the software worked for me. Running the software and then connecting gave me a USB 2 connection in the softwares eyes.
I was worried my cheap cable with extender was at fault,, seems you just need to do things in order.
