Help, Can't get video out.
9 Apr 2007
Got a new MSI B550 board with a 3700x, stuck my old EVGA GTX 670 in and at first got a message saying "there is no gop support detected in this card"
Looked up that and it's because it's an older card.
However I can't get video out of the onboard either via the HDMI or Display port?
I don't have a jumper to reset the bios but took the battery out for 10 seconds and still nothing.
All the fans spin up but I get nothing.
Your CPU has no built in GPU so the motherboard outlets will not work.
I'm surprised a GTX 670 wouldn't work in your set-up. Does the GPU work in another computer?
It's been a while since I've used the card, but it worked fine last I remember.
Should I still be able to get in the bios?
From a super quick googlage it sounds like you can get a modified BIOS to support UEFI boot for the card, but without that it won't display an image.
Edit: modified video BIOS that is, not motherboard
Yeah saw that but have no way of flashing.
How does it show the message then? Annoying that it doesn't show you to access the BIOS.
