Ok I've got a problem and needing some help trying to diagnose so I hope you guys n gals can offer some advice.
Heres the rigs specs;
Mobo: ASUS M4A7B-E
Chip: Not sure
Memory: 16GB GSkill F2-6400CL4D (4GB x 4)
GFX: ATI Radeon HD 48901
HDD: 2 x 500GB Hitachi Deskstar
PSU: Toughpower 750W
Heres the problem;
It wont even POST. PSU appears to come on, lights n fans power up, HDD's power up. No signal from the machine and no beeps from the onboard speaker.
Heres the single interesting diagnostic point. When you try and turn the power off via ATX power switch it fails to respond. You HAVE to toggle its power from the back.
Current progress
Id initially got the rig with reports that 'I think the gfx card is broken' so I started to strip it down and test the parts individually in my rig.
Memory and GFX card test and work fine.
At this point I pretty much assumed it was a faulty PSU and told my friend to check out Overclockers. He purchased a rather nice OCZ ZX 850W which I rewired into his rig.
The problem persists, right down to the ATX refusing to power off from its front switch.
I then stripped his rig down to the following components;
Mobo
PSU (OCZ)
GFX
It still failed to get to POST.
Any options or advice?
Mobo: ASUS M4A7B-E
Chip: Not sure
Heres the problem;
Current progress
Mobo
PSU (OCZ)
GFX
